Lion Dance Pen Holder design project
✨ Work analysis: Laser cutting wooden lion dance themed pen holder
This design drawing is applicable to3mmComposite board,
This is a typical laser cutting maker's work, and it is also a very suitable project for classroom teaching, combining practicality, craftsmanship, and cultural significance.
🔧 Core Process and Structure
1. Production method: Using oak plywood and laser cutting+The carving process is completed. The slight burn marks on the cutting edge are a typical feature of this type of process, while achieving high-precision machining without tool wear.
2. Structural design: Adopting a mortise and tenon joint structure, consisting of eight side panels and an octagonal base at the top and bottom/The top cover is assembled without the need for glue, making it a classic example of splicing structure in laser cutting teaching.
3. Function positioning: As a stationery storage pen holder with sufficient capacity, it can hold multiple pens; It is also a carrier for showcasing traditional patterns.
🎨 Cultural and Design Highlights
• Lion awakening theme: One side panel is carved with a complete lion awakening image, with the element of "fu" below the lion head, which is a classic symbol of Lingnan traditional culture, symbolizing auspiciousness, exorcism, and blessings.
• Text and Decoration: The side panel is carved with elements such as "traditional culture" and cartoon cat sketches, which not only echo the theme but also reflect the characteristics of personalized design.
• Scalability: The octagonal structure provides space for multi-faceted design and is very suitable for carrying out "cultural theme" series creation, such as replacing with other intangible cultural heritage patterns, class elements, etc.
💡 Teaching and Creative Expansion
1. Classroom teaching value:
◦ Can be used as an introductory project for laser cutting, learningCADBasic skills such as drawing, mortise and tenon structure design, and parameter setting.
◦ Integrating traditional cultural elements to achieve 'technology'+Interdisciplinary teaching of culture.
2. Optimization and renovation suggestions:
◦ You can apply varnish or wood wax oil to the wooden board to enhance its texture and durability.
◦ Magnetic suction structure can be added to the side panel to achieve modular replacement and create a "cultural display pen holder" with replaceable themes.
◦ You can also add it to the top coverLEDLamp trough, transformed into desktop ambient light, expanding more functions.
Drawing Cover - Lion Dance Pen Holder
CO2 RF tube
40w
1:4:11
process parameters
cutting 3mm Horizontal unidirectional - - 1
Pen holder assembly process
Insert the vertical strip of the facade into the base plate and fasten the circular top to complete the task.psFollow the order of plate making, otherwise the image will be incomplete.
Related Recommendations
comment (2)
clqbqcfm
666666666
2026-5-22 10:33
WeChat users_50
What is the compensation setting for the groove? My typing is so loose
2026-5-28 15:43
drawing ID: SUCAI-1317 2026-5-20 19:34
19
0Contribution points
label
Update time 2026-5-20 19:34
