World Heritage Miniature Model Photo Frame design project
World Cultural Heritage Photo Frame1
Drawing Cover - World Cultural Heritage Photo Frame1
CO2 RF tube
0:14:47
process parameters
cutting 3mmSegmented wooden board Horizontal unidirectional 99 30 1
Draw lines 3mmBasswood board Horizontal unidirectional 50 800 1
Design the overall cutting range, line drawing pattern, and signature
Cut and assemble
The three small squares inside the rear support frame are used as rivets (with tolerance settings that can be tightened), do not discard them. Top half of the photo frame6Fill all the holes with these six small squares. lower part6Just insert a support bracket into the hole.
drawing ID: SUCAI-1552 2026-8-6 10:16
10Contribution points
Update time 2026-8-6 10:16
