Pingdu Eight Scenic Spots design project
The work selects the classic eight scenic spots of Pingdu and the landmark building Tian Dan Huo Niu Zhen sculpture as elements, with front and back stacking, supplemented by lighting, to create a warm night light.
Pingdu Night Light Final Draft 2-in-1
Drawing Cover - Pingdu Night Light Final Draft 2-in-1
2:3:25
1、 Image processing
The selected flat scenery is a Paper Cuttings work, but after extracting the contour, many small places are not convenient to add. inLasermakerSummarized and refined, but retained as many details as possible.
2、 Cutting test
After cutting the official drawings, there was a problem of loose mortise and tenon joints, but after adjustment, it met the expected requirements.
3、 Lighting Design
To enhance the overall coherence of the work, I placed the lighting and power inside the small night light and turned it on and off through the button hole. However, multiple errors occurred during the design process, mainly due to issues with the installation position and hole placement.
4、 Assembly and debugging
After completing everything, assemble it and shoot it in the application scenario. After editing, release the video.
comment (2)
z2bvyvq7
Where did you download it? I can't find it
yesterday 20:59
z2bvyvq7
Why can't I open this What software is needed to open
yesterday 21:49
drawing ID: SUCAI-296 2024-5-19 10:25
30Contribution points
Update time 2024-5-19 10:25
