Rushan Nightlight design project
description
[font=Microsoft YaHei][size=15pt]1、 Design concept:
[font=Microsoft YaHei][size=16px] In the southeastern part of the Shandong Peninsula, there is a large Rushan mountain, which is named after it. It is a longevity town in the coastal area, where not only delicious seafood but also beautiful scenery can be found. Darushan nurtured the culture of maternal love. During the War of Resistance Against Japan, the wet nurses at Jiaodong Nursery sacrificed themselves to raise the Eighth Route Army1223Famous children, they would rather sacrifice their own flesh and blood to preserve the flame for the Eighth Route Army. Here, maternal love culture is permanently inherited.
[font=Microsoft YaHei][size=15pt]2、 Inspiration source:
[font=Microsoft YaHei][size=12pt] This project has chosen Rushan3The landmark buildings include the Mother's Love Culture Square statue, Yintan Thumb, and Furu Donghai Cultural Park sculpture. Set against the backdrop of the Mother's Love Culture Square sculpture, proceed with the Fu Ru Donghai Cultural Park sculpture and the Thumb sculpture in sequence.
Rushan Nightlight
Drawing Cover - Rushan Nightlight
0:7:16
Outline drawing
As Rushan is a small town, there are hardly any hand drawn landmark building images available online. Therefore, I chose to download relevant landmark images and use a light and shadow magic hand to convert them into a sketch style, Import again intolasermakerUse the curve tool to trace them one by one.
drawing
Select a suitable template from the gallery and match the outline drawn in the previous step with4Combine the boards one by one and group them together, aligning them in the center at any time to see the effect. Break and delete any excess lines, then arrange the layout, set the layers and processing parameters, where red represents line drawing and black represents cutting, to obtain the final processing drawing.
assembly
Take out all the cut parts, roughly arrange them, and check the effect. Then, use hot melt glue to stick the small lights from the back board to the front, and try to stick the small lights and wires on the back of the first three boards as much as possible. This way, the small lights and wires can be hidden well, achieving the effect of not seeing the light but seeing the light.
It should be noted that this work is relatively small, although laser compensation is set, placing the opening of the surrounding structure below can make the work more stable; Applying a small amount of glue at the bend can to some extent prevent it from breaking.
physical video
Rushan Nightlight
drawing ID: SUCAI-302 2024-5-19 17:05
10Contribution points
Update time 2024-5-19 17:05
