Dragon patterned night light design project
Author: Xiao Jiahao
1、 Design concept
My little sister sleeps by herself at night and cries when she wakes up in the middle of the night. Mom asked me to help make a small night light. However, too bright lights can have an impact on children's eye development, so night lights should not be too bright.
2、 Inspiration source
This year is the the Year of the Loong, so I want to use the dragon as the blueprint. At the same time, when other light sources are turned off, a rising dragon shaped pattern will have a mysterious Eastern atmosphere under the influence of the light, making people feel very peaceful.
Drawing Cover - Dragon patterned night light
0:3:8
step1
Search for dragon shaped graphics and grid styles in the browser, filter and select the most satisfactory image, and use contour extraction function to extract the lines of the pattern.
step2
Take the outline in the template, then combine it, check the order of the processing technology (cutting at the end), and add the water nozzle.
step3
Show the process of assembling cut parts into finished products
drawing ID: SUCAI-327 2024-5-21 15:15
10Contribution points
Update time 2024-5-21 15:15
