Laser cutting design diagram | revolver design project
A revolver, usually equipped with a revolver5or6A chamber that serves as both a magazine and a rotating wheel for loading bullets, allowing the bullets to be fired one by one towards the barrel and firing mechanism.
The structure is simple, the action is reliable, the initial firing is rapid, the number of bullets stored in the revolving chamber is clearly visible, and blind fire bullets are easy to eliminate; However, it has a small ammunition capacity, long reloading time, low firing rate, easy air leakage in the rotating barrel, and large lateral dimensions. It usually consists of a grip seat, barrel, wheel, wheel brake device, firing mechanism, and firing mechanism.
revolver
Drawing Cover - revolver
0:1:33
drawing ID: SUCAI-403 2024-5-30 16:34
20Contribution points
Update time 2024-5-30 16:34
