Motion Sensor Light design project
1Using acrylic board to carve dragon totem lights, the size is designed to be high143mm,wide118millimeter
2Using artificial objects to create boxes, designing the dimensions of the box's length, width, and height, designing a light socket on the top, and placing an infrared human body sensing device.
3Using the control panel, infrared human body sensing device, and light strip control to turn on and off the lights
Motion Sensor Light
Drawing Cover - Motion Sensor Light
0:20:19
process parameters
cutting Basswood board3MM - - 30 1
cutting acrylic sheet3MM - 60 10 1
Draw lines acrylic sheet3MM - - 100 1
Step 1
3Using the control panel, infrared human body sensing device, and light strip control to turn on and off the lights,Write Mini Programs
Motion Sensor Light
drawing ID: SUCAI-792 2025-12-1 09:27
30Contribution points
Update time 2025-12-1 09:27
