Mirror light painting design project
This time I bring you a mirror light painting. Turning off the light is a mirror, turning on the light is a painting
Nezha
Drawing Cover - Nezha
3:5:0
process parameters
deep carving Two-color palette Horizontal unidirectional 2.5—12 1000 1
Step 1 Design concept
Everyone has used mirrors, but you must have never seen a mirror that can display images
This time, I found a type of semi transparent lens on the universal treasure and used it to make mirror lighting paintings
Its principle is that the dark environment is a mirror, while the bright environment can transmit light
Find a suitable photo frame based on the size of the lens
Pre embedding light strips in the photo frame can achieve the effect of displaying the light on image
Step 2 Equipment List
1Black and white dual color palette
2、5Vlight bar*6
3Picture frame*1
Step Three drawing
We have an idea, let's find a Nezha blueprint to carve
Step Four processed parts
Process the designed drawings, and after processing, see the following figure
Step 5 assembly
Follow the steps shown in the following figure to complete the assembly
Step 6 Finished Product Display
comment (1)
ilook8_4606
What is a black and white two-color palette? Do you have a specific purchase link?
2025-10-21 20:27
drawing ID: SUCAI-799 2025-7-21 18:06
20Contribution points
Update time 2025-7-21 18:06
