1、 Design concept
The core design concept of this work is the integration of traditional Mid Autumn Festival culture and modern scientific and technological innovation. Combining traditional Mid Autumn Festival classic cultural symbols such as the moon, jade rabbit, and reunion with laser cutting technology and light and shadow lighting effects, breaking the single form of traditional handmade production. The work aims to express the meaning of the Mid Autumn Festival, such as gazing at the moon and thinking of roundness, peace and beauty, through a simple and beautiful wooden structure and soft lighting. It aims to present traditional culture in a youthful and technological way, and achieve innovative inheritance of traditional culture.
2、 Creative inspiration
The inspiration for the work comes from the classic image of a jade rabbit praying for blessings on a Mid Autumn Festival moonlit night. During the Mid Autumn Festival, the bright moon in the sky and the jade rabbit accompanying the moon are the most representative images in people's hearts. Combining the laser woodcraft creation form of the science and technology innovation classroom, I hope to no longer use traditional painting and origami to depict the Mid Autumn Festival, but instead use precise laser cutting lines and three-dimensional hollow structures to freeze the beautiful scenes of the night sky, crescent moon, and jade rabbit gazing at the moon into scientific and technological creations that can emit light and be displayed vertically, turning static traditional cultural images into three-dimensional handicrafts with light, shadow, and temperature.
3、 Innovation of works
1. Technological innovation of traditional elements
Abandoning traditional Mid Autumn Festival handmade flat stickers and painting forms, adopting laser cutting precision technology, with neat lines and three-dimensional structures, combining traditional Chinese style images with modern scientific and technological innovation techniques, combining aesthetics and technicality.
2. Immersive visual innovation through light and shadow
The work is equipped with lighting fixtures, and after turning off the lights, the hollow pattern is translucent to present a night view effect of gazing at the moon. During the day, it is a wooden craft ornament, and at night, it is an atmospheric night light. The dual form of one object greatly enhances the viewing and practicality of the work.
3. Simple and independently designed structure
The overall composition is simple and symmetrical, with clear primary and secondary elements. The combination of jade rabbit, crescent moon, and starry sky elements is coordinated, and the structure is stable and easy to assemble. While preserving the traditional artistic conception, it incorporates modern minimalist aesthetics, which conforms to the design characteristics of simplicity, creativity, and practicality of young people's scientific and technological innovation works.
| cutting | 3mmLimewood plywood | Horizontal unidirectional | 90 | 99 | 1 |
| Draw lines | 3mmLimewood plywood | Horizontal unidirectional | 30 | 90 | 1 |
Draw vector drawings of the Moon Watching Jade Rabbit Lamp, set carving and cutting parameters, and select3mmLimewood plywood, import laser cutting software, adjust laser power and processing speed, and prepare for laser processing.
Place the wooden board into the laser machine workbench and fix it. Machine carved jade rabbit and moon hollow texture, cutting and assembling parts; After processing, remove the wood chips, clean them, and polish the burrs on the cut.
openM+Programming software, writing lighting control programs, setting upLEDDownload the program to the main control board to test whether the program can control the changes in light brightness and breathing flicker effect.
Assemble the wooden lamp frame and connect the main control boardLEDThe light strip, battery box, and switch are installed and fixed inside the light, and wired according to the program. Power on and run the program to view the light and shadow effects, and complete the Moon Watching Jade Rabbit Lamp artwork.
