Hometown Henan Nightlight design project
Henan is the core birthplace of Chinese civilization, with a long history and profound culture. As a native of Henan, I feel proud.
During the holiday, go to the state museum with your child Central Plains pagoda, Zhengzhou Convention and Exhibition Hotel, and Chenghuang Temple in Zhengzhou, learn together and communicate together.
Let children understand the regional characteristics of Henan and integrate these buildings into the design of night lights.
The night light is not just a light fixture, but also a carrier of emotions.
It carries the longing for hometown and the love for culture, and also conveys the charm and value of Henan culture.
I hope that every person from Henan who uses this small night light can feel the unique charm and profound heritage of Henan culture.
[align=center]
[/align]
0511Hometown Henan Nightlight
Drawing Cover - 0511Hometown Henan Nightlight
0:3:59
Prepare materials
The night light is composed of multiple stacked but unobstructed layers, and the design methods for these layers are similar,
Fanke Quick Map(https://kt.fkw.com/sheji.html#/m/index)Editlogo,
image processing
Open the Light and Shadow Magic Hand,Remove the background of the image and adjust the image size at the same time.
Select the cutout pen tool, automatically cutout the image, and save itpngFormat file.
Extract contour
lasermakerImport just processedPngFormat file, select the word, and then choose "Contour Extraction" from the pop-up toolbar options,
Integrate materials
Merge the framework of the material and template file,The choice here is brilliant creativity-The template of Beijing in the cultural and creative night light,
Because the template itself has already incorporated local characteristic buildings in the city, simple processing is still needed.
Use the eraser tool to break the part of the building pattern that is linked to the frame of the night light,
Then delete the distinctive architectural patterns,
You can obtain the most basic image framework. Finally, use the line segment connection tool to reconnect the broken line segments.
Combine eraser and line tools to break and reconnect the intersection of text and rounded rectangle, and finally obtain
The other layers also use the same processing method, which requires drawing by hand or finding suitable photo elements to create.
Adjust Template
Increase control of treasurehole position.
Design assembly
Work Demonstration
drawing ID: SUCAI-165 2024-5-5 22:57
10Contribution points
Update time 2024-5-5 22:57
