Quanzhou TV model night light design project
1、 Design concept
The appearance of the laser cutting night light designed in this project is based on a classic TV model, combined with elements from two famous temples in Quanzhou - Kaiyuan Temple and Jingjing Temple, integrating historical culture with modern design, and showcasing the cultural charm of Quanzhou through exquisite laser cutting technology.
2、 Inspiration source
The inspiration for the appearance of the night light comes fromRetro TV, also addedQuanzhou Radio and Television StationLogoThrough laser cutting software design, exquisite patterns of Kaiyuan Temple and Jingjing Temple were laser cut,These elements combine the modernization and historical culture of Quanzhou.Under the backdrop of yellow and colored lights, Quanzhou's rich cultural heritage and unique aesthetic value are showcased.
Exhibition image of works
Quanzhou-TV model night light
Drawing Cover - Quanzhou-TV model night light
0:4:59
Shell design
This small night light selection template2As a design foundation. First, search for vintage TV appearance pictures and design buttons, antennas, and antenna holes in sequence.
contour extraction
Search for Kaiyuan Temple in the browserThe hand drawn image extracts the lines of landmarks through contour extraction function
Drawing layout
Arrange the various contours in the template, then combine them, check the order of the processing technology (cutting at the end), and add the water nozzle.
Assembly process
demo video
drawing ID: SUCAI-251 2024-5-16 15:37
10Contribution points
Update time 2024-5-16 15:37
