Screw gear design project
Wheels are toothed mechanical parts that can mesh with each other, and they are widely used in mechanical transmission and the entire mechanical field. Modern gear technology has reached: gear module0.004~100Millimeters; The gear diameter is determined by1Millimeters~150Rice; The transmission power can reach over 100000 kilowatts; The speed can reach several hundred thousand revolutions per minute/Divide; The highest circumferential speed reaches300rice/In seconds.
Screw gear
Drawing Cover - Screw gear
0:0:29
Screw gear
drawing ID: SUCAI-329 2024-5-21 15:54
20Contribution points
Update time 2024-5-21 15:54
