Laser cutting design diagram 丨 Hot air bulb lamp design project
A hot air balloon is an aircraft that is lighter than air, with the upper half being an atmospheric sphere and the lower half being a suspended basket. The heated air inside the balloon has a lower density compared to the cold air outside, serving as buoyancy to cause overall displacement; The hanging basket can carry passengers and heat sources (mostly open flames). Modern sports balloons are usually made of nylon fabric and have openings made of refractory materials.
Hot air balloon shaped lights add a lot of innovative atmosphere to ordinary homes. Kind reminder: The design drawings must be modified according to the actual type and size of materials used before use.
Hot air bulb lamp
Drawing Cover - Hot air bulb lamp
0:3:16
drawing ID: SUCAI-384 2024-5-30 11:51
10Contribution points
Update time 2024-5-30 11:51
