Golden Kitchen God Championship design project
Design concept:Creating this Golden Kitchen God Competition aims to promote the traditional culinary culture of the Chinese nation, enhance culinary technology exchange, and promote the development of the food service industry. Children love to eat, and they have been foodies since childhood. I want other foreigners to learn more about Chinese food culture, so I have decided to create this Golden Kitchen God Competition.
[font="] Source of inspirationI have been a foodie since I was young, and I usually watch videos of the Kitchen God Championship, so I wanted to create a gold medal for myself
Medal of the Kitchen God Championship
Drawing Cover - Medal of the Kitchen God Championship
0:1:13
Appearance production
(1)On the left side of the drawing toolbar, click on the ellipse tool to draw a80*80mmThe perfect circle. Select the image with the mouse, click on the offset curve, and choose to offset inward6mm.
(2)Click on the 'Rectangle' tool to draw a35*8mmThe rectangle. Click on the 'Rounded Corner' tool to convert the two right angles of the rectangle facing upwards into a radius of2mmThe rounded corners.
(3)Click on the 'Rectangle' tool to draw a29.5*3.5mmThe rectangle. Click on the 'Rounded Corner' tool to convert the four right angles of the rectangle into a radius of1mmThe rounded corners.
(4)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the saved chef's hand drawn drawing
(5)Select straight lines and curves to draw the chef's appearance.
(6)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the saved images of the spatula and rolling pin
image9.png(7)Select straight lines and curves to draw the shape of the spatula and rolling pin. Adjust the spatula and rolling pin to the appropriate size and place them in the appropriate position on the medal
(8)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the saved poster image of the Golden Kitchen God Championship
(9)Choose straight lines and curves to trace, draw the hats inside and place them in the appropriate position, and delete the excess onesimage12.png
(10) Click on the 'Text' tool and enter 'Cast'. Click on the 'Text' tool and enter 'Gold'. Click on the 'Text' tool and enter 'Kitchen'. Click on the 'Text' tool and enter 'God'. Click on the 'Text' tool and enter 'Dispute'. Click on the 'Text' tool and enter 'Ba'. Click on the 'Text' tool and enter 'Match'. The same operation is demonstrated only once. These fonts will be adjusted to different sizes and will not match the selected font size.
step2
(1)Adjust the layer order in the bottom right corner and sort them by "line drawing, cutting" in sequence; Double click the red layer with the left mouse button to set the material, thickness, and process to oak board3mmDraw lines; Double click the black layer with the left mouse button to set the material, thickness, and process to oak board3mmCutting.
display
drawing ID: SUCAI-596 2024-6-24 19:04
0Contribution points
Update time 2024-6-24 19:04
