2024Medal Design for the 4th Mech Tank Competition design project
1、 Overall design
The Mech Tank Competition is a unique competition event in our area,2024The fourth edition will be held this year, so I designed the medals for the competition. The design of the medal will integrate technology, strength, and glory.
2、 Pattern design
There are four stars above the medal, representing that this year is the fourth edition of the competition; There are circular shapes on both sides12A small flower used for decoration, added together on both sides24Duo also implies that this year is2024Year; There are competitions in the centerLOGOComposed of a shield and axe, it symbolizes the sturdy defense and sharp charge of mecha tanks.
3、 Text Design
Inscribed below the front of the medal“2024The words "The Fourth Mech Fighting Vehicle Competition" are designed with simple and atmospheric fonts, making them easy to recognize. The front center of the medal is engraved with the words' Champion '/runner-up/The word 'third place' is used to distinguish awards of different levels. The font design is also simple and atmospheric, keeping the style consistent with the event name.
4、 Material and Craftsmanship
Medal use3mmMade of acrylic material, ensuring the texture and durability of the medal, and transparent material also enhances the visual effect.
Mech Tank Medal Design
Drawing Cover - Mech Tank Medal Design
0:6:37
Determine the circular structure outline of the medal
draw a80mmThe circle is internally offset using the offset curve tool16mmDetermine the main outline structure of the medal
Four stars represent the fourth edition of the competition
Find the pentagram in the gallery, adjust its size and position
Design circular characters by following the path with text
Text follows the path, write“2024The 4th Mech Tank Competition of the year.
Secretly tell you a secret, the little flower is in the shape of rice“*”Adjust the appropriate font by yourself!
Add in the middle of the medalLOGOdesign
Find the "axe" and "shield" in the gallery, symbolizing the sturdy defense and sharp charge of the mecha tank.J5.jpg
Add the word 'award' in the middle of the medal
Draw the suspender structure at the top of the medal
Draw the sling structure with "rectangle" and "circle", remember to chamfer!
Adjust processing technology and parameters
Adjust the processing technology and parameters, which need to be adjusted according to the actual situation. The material is3mmAcrylic!
Flip the back processing mirror left and right
My design is for back processing, so it needs to be mirrored and flipped left and right. If you want positive processing, you don't need this step, the effect is also very good!
Video Presentation
Works Display
drawing ID: SUCAI-606 2024-6-24 22:51
10Contribution points
Update time 2024-6-24 22:51
