Lingnanhong design project
Design concept: In daily life, we often see various doorplates in stores, which can give us a certain understanding of the store. Good doorplates make us shine, so I designed a doorplate for my tea shop. It is not only a fashionable item doorplate that showcases personality, but also expresses my support and expectations for my family's career.
Inspiration source: It adopts a heteromorphic frame design, and the round national style frame is inserted with the word "tea" to show the style of tea culture, which is different from the conventional signboard, giving people a sense of China-Chic elegance. Adding the tea shop name 'Lingnan Hong'logoAdding the words' Tianying is always here, welcome to come often 'to the tea garden name' Tianying 'can highlight our tea culture and hospitality. The addition of the Fengyun pattern and the tea pot and cup patterns further highlights the rich tea culture in the store, which is elegant, hospitable, and leisurely.
Lingnanhong
Drawing Cover - Lingnanhong
0:37:16
Create a list
1Style design: irregular wooden frame, Lingnan Hong pictureLogoText design, tea leaves, cloud patterned images
2Material Decoration:3mmBasswood board
3Processing equipment: laser cutting machine
Laser processing
(1)Select the default line drawing red layer for internal lines, the default light carving yellow layer for text and patterns, and the default cutting black layer for the pattern of the door frame. Adjust the layer order in the lower right corner and sort them by "line drawing, light carving, cutting" in sequence.
(2)Double click the red layer that needs to be traced with the left mouse button, select the oak board,3mmDraw lines and set processing parameters: speed is150The power is15.
(3)Double click the yellow layer that needs to be lightly carved with the left mouse button, select the oak board,3mmShallow carving, set processing parameters: speed is200The power is10.
(4)Double click the black layer that needs to be cut with the left mouse button, select the oak board,3mmCutting, setting processing parameters: speed is15The power is100.
2Processing of drawings
After setting the processing parameters, the equipment can be connected for processing.
finished product assembly
Clean the dust on the surface of the processed doorplate with a tissue, and the work is completed.
Work video
Lingnanhong
drawing ID: SUCAI-707 2024-12-29 16:45
0Contribution points
Update time 2024-12-29 16:45
