Mid Autumn Festival long ear gear diagram design project
This is a creative wooden teaching tool that combines traditional festival culture with mechanical principles——Mid Autumn Festival Gear Rabbit with Long EarsIt is designed in the shape of a cute rabbit, paying tribute to the Mid Autumn Festival legend of the "Jade Rabbit", and cleverly incorporating a prominent gear structure on its back STEMEducation is integrated into it, with both artistic appreciation and interactive learning functions.
Design Highlights: Integration of Tradition and Technology
  • Mid Autumn Festival theme: The long eared rabbit adopts a squatting posture, with a round wooden body and iconic vertical ears echoing the image of the Mid Autumn Festival "Moon Rabbit", conveying a warm festive atmosphere.
  • Gear linkage device: A rotatable gear set is embedded in the back, and the square hole design on the gear facilitates observation of the meshing principle. The limbs are linked to the gear through black connectors. When manually rotating the gear, the rabbit's limbs will move synchronously, vividly demonstrating the mechanical transmission process.
Science popularization education function: through intuitive gears-Limb linkage helps children understand basic mechanical knowledge such as gear transmission, force transmission, and motion conversion.
  • tipsSuggest using an acrylic marker for coloring. Attached with gear science popularization courseware, suitable for5-9Children's science popularization, class hours 40min.
Mid Autumn Festival Long Ear Gear Rabbit
Drawing Cover - Mid Autumn Festival Long Ear Gear Rabbit
CO2 RF tube
40w
honeycomb panel
0:14:44
process parameters
Determine the gear system
drawing ID: SUCAI-812 2025-10-1 11:51
  • classification
  • copyright
    open source licenseCC-BYAllow commercial use;
  • Business License
    Further information
label
Update time 2025-10-1 11:51
