Runner's Medal design project
Design concept: Running has been a skill of human beings since ancient times. Nowadays, the word 'running' has been given more meaning, and running competitions are also frequent visitors to major sports events such as the Olympics. When athletes stand on the podium and wear medals, an unparalleled sense of pride always surges in their hearts.
Inspiration source: The wheat ears symbolize success and honor, while the running matchstick figures represent the theme of "running". These two patterns can reflect the honor of athletes and also encourage them to keep running.
Runner's Medal
Drawing Cover - Runner's Medal
0:1:10
Step 1: Drawing Design
Draw a regular hexagon from the Kula material on the right, flip it 90 degrees, turn on the aspect ratio, and set the length to65And offset inward20mm.
Add the number one to the graphic, outline it, and input text“Top”.
draw a20x7mmThe rectangle should be aligned with the outside of the medal, and the overlapping line segments should be broken with an eraser and deleted, with a water outlet added to it.
Import the material of the wheat ear, extract the contour, make slight modifications, adapt to the medal shell, and make slight modifications to the entire medal.
Import the material of the scroll, extract the outline, and select the most suitable scroll.
Import the material of stickman and extract its outline, making slight modifications.
Place the matchstick figure into the medal, and set the areas where the outline needs to be cut as cutting, and other areas as tracing. Adjust the process sequence and fine tune the size of the water nozzle.
The final design drawings are as shown above.
Step 2: Demonstration Video
Runner's Medal
drawing ID: SUCAI-604 2024-6-24 21:57
10Contribution points
Update time 2024-6-24 21:57
