Two-color palette-ODIN32-Create a 'Toilet Sign' design project
Required materials:
Mirror dual color palette
Required software:
LaserMaker
design1
Drawing Cover - design1
0:0:36
Prepare artwork
Laser cutting machine model used:ODIN32 55w;
Lens used:ODIN32 2"lens
Vector cutting: speed:15mm/s, Power70%Corner power:20%;
openLaserMakerYou can save the design of the required signage to a custom gallery for easy use next time. Modify the pattern layer.
Determine parameters
Please refer to your user manual for recommended engraving for your machine/Cutting parameters can also be adjusted according to the material you are using (the parameters shown in the picture are only applicable)ODIN32Laser cutting machine). After completing the parameter modification, the file can be sent to the laser cutting machine.
Place materials
Place the material inodin32Adjust the laser head to the desired carving position on the honeycomb panel, and ensure that the laser head is above the material before clicking on autofocus. (If the laser cutting machine you are not using does not have autofocus function, you can use a focusing ruler to focus.) The laser cutting machine autofocus is complete.
On the machine, open the file, click to confirm the border, and then press Start.
1669084504095-6d3e1212-3228-4f50-b6cd-45e18522244c.jpeg?x-oss-process=image%2Fwatermark%2Ctype_d3F5LW1pY3JvaGVp%2Csize_49%2Ctext_6Zu35a6H5r-A5YWJ6Zu35a6H5r-A5YWJ%2Ccolor_FFFFFF%2Cshadow_50%2Ct_80%2Cg_se%2Cx_10%2Cy_10
carving effect
1669084597592-41b0b3c2-44a9-41c9-90a2-2edc1c030d47.jpeg?x-oss-process=image%2Fwatermark%2Ctype_d3F5LW1pY3JvaGVp%2Csize_36%2Ctext_6Zu35a6H5r-A5YWJ6Zu35a6H5r-A5YWJ%2Ccolor_FFFFFF%2Cshadow_50%2Ct_80%2Cg_se%2Cx_10%2Cy_10
drawing ID: SUCAI-1 2024-4-1 16:16
0Contribution points
Update time 2024-4-1 16:16
