Function of the work
This work isAIIntelligent Q&A device that can achieve intelligent Q&A on knowledge related to Mid Autumn Festival and National Day. Through fun human-computer interaction, it can easily popularize traditional festival culture.
Source of inspiration
Inspired by the traditional culture of Mid Autumn Festival and National Day, in order to change the traditional dull learning methods, fun interactive installations are used to spread holiday knowledge and make holiday culture learning more vivid.
Design philosophy
This work relies onLaserMakerDesign and produce, combining traditional festival culture withAICombining intelligent technology and interactive Q&A to achieve educational entertainment, combining viewing and practical science popularization.
innovation points
Popularizing Traditional Festivals through Science PopularizationAIIntelligent interaction combined with innovative learning forms; The overall product is made of laser cut sheet metal, with a simple and orderly shape, easy operation, and strong interactivity.
Bill of Materials
3mmLimestone board, floating boardK10Empty boardK10 IOExpansion boardType‑Cdata line.
Manufacturing process
Works adopted3mmLaser processing and production of oak board, including two process parameters: line drawing and cutting: line drawing laser power20%Speed200mm/sProcessing1Secondly; Cutting laser power80%Speed15mm/sProcessing1Next time.
This laser cutting design participated in the activity: Full Moon, Home and Country, Double Festival of Wisdom and Fun —— AIMid Autumn Festival and National Day Special Laser Creation Competition Event
| cutting | 3 mm Basswood board | Horizontal unidirectional | 80 | 15 | 1 |
| Draw lines | 3 mm Basswood board | Horizontal unidirectional | 20 | 200 | 1 |
| Shallow carving | 3 mm Basswood board | Horizontal unidirectional | 30 | 180 | 1 |
openLaserMakerSoftware, first use the quick box making function to create the box body, and design the mortise and tenon concave convex joint structure. Select two images of the national flag and Chang'e as materials to import into the software. Use the line extraction function to convert the images into vector contour lines, clean up excess lines, merge the patterns and box drawings for layout, and divide the areas for shallow carving, line drawing, and cutting.
useType-CData cable empty boardK10Connect the computer, boot up and enter the system, open XiaozhiAITools. Upload and burn the pre written Mid Autumn Festival and National Day Q&A program to the Hangkong board, and enter the relevant Q&A content for the festival. After the burning is completed, connect the line blank board expansion board, install the hardware into the box, and power on for testingAIQ&A function.
