helicopter model design project
Design Scheme for Laser Cutting Helicopter Model
1、 Design concept
With the core of "lightweight expression of mechanical aesthetics", the complex industrial structure of helicopters is disassembled into touchable flat modules, and the mechanical details are restored through the precision of laser cutting. At the same time, guided by the principle of "assembly is experience", users can feel the logical beauty of aviation machinery during the splicing process, realizing the creative pleasure of "from flat to three-dimensional, from parts to the whole machine", and creating models that are both ornamental and interactive.
2、 Inspiration source
Inspiration comes from the fusion of two aspects: one is military/The industrial design of civilian helicopters focuses on the functional structural proportions of their rotors, fuselage, and landing gear, with the aim of preserving the mechanical features that are recognizable and detailed; The second is the interactive logic of modular assembled toys, which refers to the "low threshold assembly" experience of jigsaw puzzles and building blocks, breaking down the barriers of traditional models with "high difficulty and high cost", and transforming the "flat advantage" of laser cutting into the value of "easy to use and carry".
3、 Core innovation points
(1) Design Innovation: "Precise Details+Lightweight Visual Balance
Abandoning the traditional model of "heaviness", all parts adopt2.4mmThin sheets (such as oak boards and acrylic) are laser cut with micrometer level precision to restore key details of helicopters on the thin sheets, ensuring visual "mechanical recognition" and avoiding the heaviness after assembly, suitable for desktop placement scenarios.
(2) Structural innovation: "Toolless snap fit splicing"
Breaking through the traditional assembly method that relies on glue and screws, all connection parts are designed with laser pre cut buckle structures, which do not require additional tools during assembly. They can be fixed by simply pressing and clamping, and the disassembled parts have no loss and can be reassembled repeatedly; At the same time, the main body of the aircraft adopts a "segmented structure", and the rotor, tail beam, and landing gear can be independently disassembled for easy storage and carrying.
(3) Functional innovation: static display
 1.       Static mode: After assembly, the fuselage remains stable and stands, simulating the state of a helicopter "parked and waiting", serving as a desktop decoration with mechanical aesthetics;
(4) Technological Integration Innovation: "Laser Technology+Deep adaptation of material properties
Fully leverage the technological advantages of laser cutting to achieve bidirectional adaptation between "process and design":
 For wooden boards, the "thermal burning effect" of laser is used to create a subtle wood grain texture at the edges of the parts, enhancing the natural texture;
Many parts' edges are laser "rounded" to avoid sharp burrs after cutting, improve safety during assembly, and are suitable for most users.
helicopter
Drawing Cover - helicopter
semiconductor(blue light)laser
60w
0:13:19
process parameters
cutting acrylic Horizontal unidirectional 80 10 1
1Draw the required parts using drawing software
2Arrange the layout of the drawn graphics
comment (5)
18525380833
111、
2025-12-9 15:26
,,,,_10
rice cooker
2025-11-4 15:41
,,,,_10
Goose goose goose
2025-11-4 15:41
54oqgith
Cannot be spliced together
2026-2-7 13:44
hawk
Thanks for sharing.
2026-2-14 12:32
helicopter model
drawing ID: SUCAI-823 2025-10-29 12:08
10Contribution points
label
Update time 2025-10-29 12:08
