Star orbit exploration design project
Drawing video
Design philosophy
The base of the work adopts a solar system operation model, which allows viewers to understand the names, motion trajectories, and laws of the major planets in the solar system, thereby arousing infinite longing and exploration enthusiasm for the vast universe.
The satellite model shuttles beyond the solar system and is the main part of the overall work, symbolizing the boundaries of human understanding of the universe; It also symbolizes that beyond the known solar system, there are endless mysteries waiting for us to discover in the depths of the universe. China's aerospace industry still needs to forge ahead and constantly explore unknown fields.
Source of inspiration
When it comes to aerospace, symbols such as rockets and spacecraft undoubtedly come to mind; Following closely behind is the vast planetary universe. The work carefully selects objects with profound symbolic significance to highlight the core theme of this event. The deep intention of the work is to allow viewers to intuitively feel the laws of the solar system's operation while appreciating the work, thereby expanding the public's understanding of the aerospace field: viewers can see in detail the Chinese and English names and trajectories of the planets in the solar system in the work. The work also aims to arouse viewers' enthusiasm for aviation and aerospace, pay attention to China's progress in the field of aviation and aerospace, thereby enhancing national self-esteem and contributing to the aerospace industry.
innovation points
Design: Rich colors that can attract viewers' attention; Marked with textual information to facilitate the purpose of popularizing the work.
Structure: Strong interactivity and mobility, achieving rotation of star orbits through a simple structure; The materials used are quite diverse, including3mmLimestone board3mmNon woven fabric and0.6mmCardboard, anodized aluminum color cards and tin foil are used in decoration.
Function: Viewers can manually rotate the star orbit to understand relevant information.
related activities
This laser cutting design participated in the activity: Interstellar Creativity, Intelligent Future Creation "- Aerospace themed Laser Creation Competition
satellite
Drawing Cover - satellite
Carbon dioxide glass tube
40W
0:0:52
process parameters
cutting 0.6mmcardstock - - - 1
star trail
Drawing Cover - star trail
40W
0:2:43
process parameters
cutting 3mmBasswood board - - - 1
Shallow carving 3mmBasswood board - - - 1
planet
Drawing Cover - planet
40W
0:11:13
process parameters
cutting 3mmnon-woven fabric - - - 1
deep carving 3mmnon-woven fabric - - - 1
drawing drafting
1.Star orbit: Use concentric circle shapes, adjust dimensions, and draw6A circle and a gasket; And drill holes at the center and edge positions of the circle according to the diameter of the bamboo stick (considering cutting loss, the hole at the center position is slightly larger than the diameter of the bamboo stick, and the hole at the edge position is slightly smaller than the diameter of the bamboo stick).
2.Satellite: After calculating the drawing data, use concentric circle shapes, rotation, and eraser tools to draw satellite drawings.
3.Planet: Import vector graphics and extract contours, separate layers, and use different colors for differentiation.
laser cutting
coloring
Use watercolor pens and color powder to color the star orbit and satellite columnar structures.
Assembly adhesive
Assemble the planet with hot melt adhesive and bond it with a short wooden stick. Insert the short wooden stick with the planet into the small hole near the edge;
Insert the star orbit and gasket into the bamboo stick to ensure its rotation.
Glue the satellite according to the adhesive location, fix the blue anodized aluminum plate that serves as the solar panel, and decorate it with tin foil.
Finally, assemble the two.
drawing ID: SUCAI-825 2025-10-28 18:33
30Contribution points
Update time 2025-10-28 18:33
