1、 Title of work
Laser cutting wooden creative night light
2、 Overview of the work
This work is a wooden hollow night light made based on laser cutting technology. It is made of oak wood as raw material and assembled through precise laser engraving and cutting, combined with mortise and tenon structure. The work is composed of a hexagonal base and a star shaped hollow lampshade, with "starry sky" as the core design element. It combines traditional woodworking techniques with modern laser processing technology, combining creativity, practicality, and artistic expression.
3、 Design concept
The work is based on the core inspiration of "stars hanging in the flat field, warm light accompanying sleep", focusing on the characteristics and advantages of laser cutting technology for creation:
1. Theme expression: Echoing the image of "starry sky" with hollow patterns of stars, the staggered arrangement of star shaped holes breaks the monotony of the plane, allowing light to pass through and form a layered light and shadow effect, conveying a healing and warm atmosphere;
2. Structural ingenuity: The design of using a hexagonal base with mortise and tenon joint lampshades ensures the stability of the base and can be assembled without the need for additional glue, fully demonstrating the advantages of laser cutting technology in precision splicing and standardized processing;
3. Integration of Materials and Craftsmanship: Using oak wood panels, the natural natural texture of the wood contrasts with the precise lines of laser cutting, retaining the warmth of handmade craftsmanship while reflecting the precision of modern craftsmanship.
4、 Production process and technical implementation
1. Material selection: Adopting3mmLimewood plywood has a uniform texture and is easy to process. After laser cutting, the edges are smooth without burrs, and the natural texture adds a natural texture to the work;
2. technological process:
◦ Design phase: UseCADSoftware drawing of various component drawings, planning of mortise and tenon joint structures and star hollow patterns to ensure accurate matching of component dimensions;
◦ Laser processing: The cutting and carving of the board are completed through a laser cutting machine. The cutting power and speed parameters have been adjusted multiple times to ensure that the mortise and tenon grooves are tightly fitted, and the edges of the hollow pattern are clear and free of focal edges;
◦ Assembly stage: Using a non adhesive mortise and tenon joint method, the base side panel, top cover, and lampshade components are assembled in sequence, with a stable and detachable structure, reflecting the convenience of modular design;
3. Craftsmanship highlight: By utilizing the high precision of laser cutting, the combination of complex hollow patterns and precision mortise and tenon structures is achieved, which not only demonstrates the precision of the craftsmanship, but also ensures the practicality and aesthetics of the work.
5、 Function and innovation points of the work
1. Practical function: Can be built-inLEDLamp beads are used as night lights, projecting starlight and shadows through star hollows. The light is soft and not dazzling, suitable for use in dormitories and bedrooms;
2. Technological innovation: Combining traditional mortise and tenon structures with modern laser cutting technology, stable splicing can be achieved without the need for glue, fully leveraging the advantages of standardized and high-precision laser processing;
3. Creative expression: Combining simple geometric shapes with starry sky elements, breaking the rigid design of traditional wooden night lights. The combination of light and shadow effects and natural wood texture makes the work both decorative and atmospheric.
6、 Summary of the work
This work is centered around laser cutting technology, combining creative design, precision machining, and practical functionality. Through precise size control, smooth line cutting, and clever mortise and tenon joints, it showcases the potential of laser cutting technology in the production of wooden creative works. The work is not only a decorative and practical night light, but also a practical exploration of the integration of traditional craftsmanship and modern technology, fully reflecting the precision, convenience, and creative expression of laser cutting technology.
