Excellent Physics Team Leader design project
Design concept:This medal design combines modern art and traditional elements, aiming to celebrate outstanding achievements and unremitting efforts. The main body of the medal is made of acrylic material, and the edges are finely polished to show a smooth and bright texture. The front center is embedded with an atomic nucleus and extranuclear electrons of the physical world's atomic motion trajectory, surrounded by exquisite floral patterns inspired by rice ear patterns, symbolizing the perfect combination of inheritance, innovation, and harvest glory. The back of the medal can be engraved with the name of the winner and the award date, presented in simple and elegant font, enhancing the commemorative significance of the medal. In addition, the medal is equipped with a blue silk ribbon, which corresponds to the material of the medal, and the overall design is elegant and layered. The design elements of the medal complement each other, showcasing a harmonious beauty. This medal is not only a symbol of honor, but also a recognition of the team leader's long-term dedication and responsibility, representing a high degree of recognition and respect for the outstanding achievements of the winners. Each medal is unique and has extremely high collectible value.
Source of inspirationThe inspiration for creating this excellent physics team leader medal comes from admiration for the spirit of scientific exploration and deep respect for educational contributions. Physics is a discipline that reveals the mysteries of nature, and its complexity and profound impact are fascinating. The original intention of designing this medal is to recognize outstanding students who have worked hard and continuously innovated in physics learning and work. Firstly, the overall design inspiration for the medal comes from the orbits of planets and the structure of atoms in the universe, which are important symbols of physics. The design in the center of the front adopts a pattern of atomic nuclei and electron orbitals, symbolizing the core of knowledge and the spirit of continuous exploration. This pattern not only showcases the wonderful structure of physics, but also symbolizes the core role played by the physics team leader in the educational process. The electrons in orbit symbolize every ignited spark of wisdom, and every star represents an inspired student. At the edge of the medal, there is a wheat ear relief pattern engraved. This design is inspired by the image of hybrid rice cultivated by the great scientist Yuan Longping, and also symbolizes the physics team leader's selfless dedication to students and persistent pursuit of education. Clearly written above2024The outstanding physics team leader in eighth grade, below is this medal2024Established annually. In order to reflect the precision and rigor of physics, the medal production process uses a combination of acrylic and oak board, which not only has the texture of acrylic, but also reflects the layering of the design. This excellent physics team leader medal is not only a symbol of honor, but also a recognition and encouragement of the hard work of the physics team leaders. I hope that through this medal, we can cultivate more generations who love science and are brave in innovation.
Acrylic part of medal
Drawing Cover - Acrylic part of medal
0:2:57
3mmLimestone board section
Drawing Cover - 3mmLimestone board section
0:2:13
Outline drawing
1.In the menu bar, click on 'Create' and select 'Badge'/Seal, with an outer diameter set to70mmThe inner diameter is set to53mmThe circular shape. text1The content is“2024Excellent Physics Team Leader for Grade 8 ", with a high level of writing4Text offset2Text spacing4Black body; text2The content is“Established in 2024”, text height4Text offset2Text spacing0.8; Text3Empty. Click on 'Confirm' in the bottom left corner.1.png
2.Set the outer ring to cut
3.Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the saved wheat ear image.
4.Click the left mouse button to select the image, then click to extract the contour and delete the image to obtain the shape of the wheat ear.
5.Click the mouse to select the shape of the wheat ear, delete the excess parts, leave the desired pattern, and modify it to yellow light carving.
6.Select the pattern, hold down to rotate it to the appropriate angle, hold down the surrounding four corners to reduce the size, and place it in the appropriate position on the medal.6.png
7.Select the above pattern and right-click to set it as' Group '.
7.Use the Polygon Tool on the left to draw a polygon with the number of edges6The length is50mmThe hexagon.
8.Draw a rectangle using the 'Rectangle' tool80mm*60mmSubtract the excess hexagons from the 'difference set' on the left to form a trapezoid.
9.Move this trapezoid above and merge it with the medal for merging
10.Use the 'Rectangle' tool on the left to draw a12mm*4mmDrag the rectangle to the top of the medal with the mouse, and the hook will be ready.
11.Click on the 'Ellipse' tool on the left to draw a70mm*70mmChange the circle to a straight line and move it inside the medal.
12.At this point, the acrylic board section has been fully completed, the parameters have been set and sent to the machine for installation3mmAcrylic is cut.
13.Find an atomic structure model diagram and clicklasermkerThe file in the menu bar can be opened by pulling down.
14.Crop and contour the image in sequence
15.Select the image and choose shallow carving.
16.Copy the inner circle of the medal50mm*50mmSet as cutting, move the above image to the center of the inner circle.
17.So far,3mmThe oak board section has been fully completed.
Laser processing
1.Acrylic section: Adjust the layer order in the lower right corner and sort them by "line drawing, light carving, cutting" in sequence; Double click the red layer with the left mouse button to set the material, thickness, and process to acrylic3mmDraw lines; Double click the yellow layer with the left mouse button to set the material, thickness, and process to acrylic3mmShallow carving; Double click the black layer with the left mouse button to set the material, thickness, and process to acrylic3mmCutting.
2.Lime board section: Adjust the layer order in the lower right corner and sort them by "line drawing, shallow carving, cutting" in sequence; Double click the red layer with the left mouse button to set the material, thickness, and process to oak board3mmDraw lines; Double click the yellow layer with the left mouse button to set the material, thickness, and process to oak board3mmShallow carving; Double click the black layer with the left mouse button to set the material, thickness, and process to oak board3mmCutting.
Assembly of works
Color the wooden board with acrylic pigment, bond the wooden board and acrylic board with solid adhesive, fasten the blue silk tape, and complete the production.
demo video
drawing ID: SUCAI-448 2024-6-24 10:32
0Contribution points
Update time 2024-6-24 10:32
