[Reference Example] Alien Luminous Work Sign design project
Design concept:In daily life, we often use identification cards such as work cards, competition cards, and campus cards, but traditional identification cards are often generic and lack individuality. We break the norm and bring a brand new alien glowing work badge, which is not only a practical equipment, but also a fashionable item that showcases personality.
Source of inspirationAdopting a framework design of the opposite sex, different from conventional rectangular work boards, giving people a high-tech feel. Added itLaserMakeroflogoThe text on the 'Work Permit' and '6th Laser Creation Competition' can highlight the usefulness of this work badge. Assembled with luminous accessories, the work card can present different color effects, and different colors can be used to distinguish different work properties, making the function of the work card more flexible.
Special note: When uploading your work, please make sure to select the correct work category. The selected work category for this competition is the 'Identification Label Competition'. At the same time, it is necessary to choose the theme of the 6th eventLaserMakerLaser Creation Competition Event.
[attachmentID:1366 - Attachment does not exist]
Alien luminous work card
Drawing Cover - Alien luminous work card
Carbon dioxide glass tube
1:29:48
process parameters
Shallow carving 3mmacrylic Horizontal unidirectional 20 500 1
cutting 3mmacrylic - 70 20 1
Create a list
1Style design: opposite sex borderLaserMakerimageLogoText Design
2Material Decoration:3mmTransparent acrylic, luminous accessories, red ribbon
3Processing equipment:Thunder Bolt Plus
design process
1Draw the outer frame of the work card, design the internal pattern and add some details, and add text andlogo.
2Select all graphics and click on the 'Horizontal Mirror' tool.
Laser processing
1Set processing layers and parameters
(1)Select the default light carved yellow layer for the internal pattern and the default cut black layer for the pattern on the outer frame of the work card. Adjust the layer order in the lower right corner and sort them by "light carving, cut" in sequence.
(2)Double click the yellow layer that needs to be lightly carved with the left mouse button, select acrylic,3mmShallow carving, set processing parameters: speed is500The power is20Horizontal unidirectional, weak blowing.
(3)Double click the black layer that needs to be cut with the left mouse button, select acrylic,3mmCutting, setting processing parameters: speed is20The power is70Strong blowing.
2Processing of drawings
After setting the processing parameters, the equipment can be connected for processing. Kind reminder: To avoid laser reflection, the protective film of the acrylic board can be peeled off only the side that needs to be carved, and the other side can be peeled off after processing.
finished product assembly
Clean the dust on the surface of the processed work card with a tissue, install the luminous accessories and webbing, and the work is completed.
Here are more reference cases about luminous work signs. Welcome everyone to unleash unlimited creativity together!
Work video
drawing ID: SUCAI-680 2024-11-29 11:59
0Contribution points
Update time 2024-11-29 11:59
