Laser Creation Beginner Course | Case 10: Loong Boat Printmaking design project
Printmaking is a type of artwork that is carved or etched onto wooden, stone, linen, copper, zinc, or other surfaces using knives or chemicals, and then printed. In this issue, we use "laser cutting" instead of traditional "hand carving" to make prints, and take Loong Boat Festival as the theme of prints. In this issue, the little laser expert brings you the work "Loong Boat Printmaking"!
border
Drawing Cover - border
0:1:25
Dragon Monday Printmaking
Drawing Cover - Dragon Monday Printmaking
0:14:3
Appearance production
(1)Enter the keyword "Loong Boat Painting" in [Baidu Encyclopedia], and select your favorite picture to save; Click on 'File' in the 'Function Area' above, and then click on 'Print'
Open], double-click to open the saved Loong Boat picture, as shown in the following figure:
(2) Left click the picture, click to extract the outline, delete the redundant lines and background, and add some strokes appropriately to get the Loong Boat line diagram, as shown in the following figure:
(3)From the Drawing Toolbar on the left, select the Horizontal Mirror tool to mirror the Loong Boat painting once, as shown in the following figure:
Tips:Note: During the printing process, a mirror image will occur, and the printed image will be a mirror image of the original image; If a mirror image is first performed during the design drawing processing, the printed image will be the original one.
(4) Divide the Loong Boat painting into different layers according to different colors, and get five layers in total
(5) Divide the Loong Boat painting into different drawing boards according to different layers, and get five drawing boards in total:
(6) From the Drawing Toolbar on the left, select the Rectangle and Ellipse tools to draw the frame mounted with "Loong Boat Printmaking" and the dust cover of the frame, as shown in the following figure
Show:
Tips:The four circles on the left frame are used to place rivets to secure the frame and dust cover.
Laser processing
(1)Select the "dust cover" and left click on the layer panel in the lower left corner to change the layer to red, as shown in the following figure:
(2)Double click the red layer with the left mouse button to set the material, thickness, and process to acrylic3mmCutting; Double click the left mouse button on each remaining layer to select the material, thickness, and texture
The art is set as oak board3mmCut, as shown in the following figure:
Finished product display:
Summary:
   In the production process of this example, we need to consider the issue of mirroring. How can we design and print to obtain the pattern we want? In addition, during the coloring process, the laser expert used acrylic pigment for the first time and found it impossible to print the pigment onto paper. After searching for information, the laser expert learned that they should choose the correct pigment - ink pigment - for coloring. When encountering difficulties, young designers can also try to solve problems on their own by searching for information! Drawing and modeling are not difficult, everyone must try and practice more to become a better little designer!
drawing ID: SUCAI-18 2024-4-3 17:59
0Contribution points
Update time 2024-4-3 17:59
