Laser Creation Beginner Course | Case Seven:DIYRubber tile printing design project
Seal painting refers to the use of seal painting by emperors on edicts or memorials. I hereby approve. Seal painting is a type of seal, but it is different from seals. Prints belong to a type of material that can be carved with various patterns, such as character portraits, cartoon images, flowers, trees, and so on. Dip it in ink and gently press it to leave your favorite patterns on paper. This issue brings to everyone “DIYRubber tile printing " The production method!
Maple block carving
Drawing Cover - Maple block carving
0:0:25
Rubber pad carving
Drawing Cover - Rubber pad carving
0:0:2
Draw the appearance
(1)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the desired material image, and adjust it to the appropriate position within the rectangle, as shown in the following figure:
(2)Select the image and change its size to long from the 'Drawing Toolbar' above59mm, wide59mmThen move the graphic to align with the bottom left corner of the rectangle
As shown in the following figure:
(3)Select the image and place the mouse on the 'Horizontal Mirror' pattern from the 'Drawing toolbar' on the left. Click the left mouse button on 'Horizontal Mirror', as shown in the following figure:
Tips:Due to the reflection of the pattern obtained when using printing, it is possible to mirror the pattern once during printing, so that the desired normal pattern can be obtained when using printing.
Laser processing
(1)Double click the 'Processing Panel' in the bottom right corner with the mouseBlack layer,Add custom material "rubber brick", double-click "custom" with the mouse, and set English and Simplified Chinese as
rubberRubber tiles10mmDouble click the blank icon and select the image of the rubber tile material, as shown in the following figure:
(2)Double click the 'Processing Panel' in the bottom right corner with the mouseBlack layer,Set the material, thickness, and process to rubber bricks10mmShallow carving, as shown in the following picture:
Method for making beech wood blocks
1.Draw the appearance
(1)Open itLaserMakerSoftware, select the "Rectangle" tool from the "Drawing Toolbar" on the left, then move the mouse to the drawing area and hold down the left mouse button
Drag and drop on the drawing area to draw a length of59.3mmThe width is59.3mmThe rectangle; Select the 'Ellipse' tool, then move the mouse to the drawing area and hold down the left mouse button while drawing
Draw the diameter on the map area as7.8mmThe perfect circle is shown in the following figure:
Tips:The production of a perfect circle is used to drill holes and connect the handle with a wooden block of beech wood.
(2)Select the rectangle and circle, and place the mouse on the "Left Alignment" pattern from the "Drawing Toolbar" on the left. Multiple alignment methods will appear, and then click the left mouse button first
Click on 'Horizontal Alignment', then left click on 'Vertical Alignment' with the mouse, as shown in the following figure:
(3)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the image that needs to be carved, as shown in the following figure:
(4)Select the image and change its size to long from the 'Drawing Toolbar' above45mm, wide45mmThen move the graphic to align with the bottom left corner of the rectangle
(5)Select image 'Paul Walker'1”Left click on 'Image Extraction' in the graphic to extract the imageDPIchange to300Make the image clearer, as shown in the following picture:
(6)Click on 'File' in the upper 'Function Area', then click on 'Open', double-click to open the desired material image, and adjust it to the appropriate position within the rectangle, as follows
As shown in the picture:
Tips:This material image was not added to the rubber brick and was only placed on a beech block for decorative purposes.
Laser processing
(1)Select image 'Paul Walker'1”Left click on the layer panel in the lower left corner of the mouse to change the contour layer to yellow; Select a perfect circle, left click on the layer panel in the lower left corner of the mouse to change the contour layer to
Purple; Select the image material "Paul Walker Car Text Material", left click on the layer panel in the lower left corner of the mouse to change the contour layer to blue, as shown in the following figure:
 (2)Double click the 'Processing Panel' in the bottom right corner with the mouseBlack layerLeft click on the right eye icon with the mouse to hide the layer, as shown in the following figure:
(3)Double click the 'Processing Panel' in the bottom right corner with the mouseYellow layer,Add custom material "beech wood", double-click "custom" with the mouse, and separate English, Simplified Chinese, and Traditional Chinese
Don't set it asbeechBeech wood, beech wood10mmDouble click the blank icon and select the beech wood material image; Set the material, thickness, and craftsmanship to beech wood10mm、
(4)Double click the 'Processing Panel' in the bottom right corner with the mousePurple layer,Set the material, thickness, and craftsmanship to beech wood10mmDeep carving; Double click on the bottom right corner with the mouse to select 'Processing'
The panelBlue layer,Set the material, thickness, and craftsmanship to beech wood10mmShallow carving; Adjust the positions of several layers in the order of "light carving, deep carving" as follows
Works Display
summary
In the process of creating this example, we learnedLaserMakerHow to use the 'Add Custom Materials' feature of the software. In the process of completing the 3D project, we need to first analyze the work, analyze its components, and then complete them one by one, and finally assemble them. Drawing and modeling are not difficult, everyone must try and practice more to become a better little designer!
drawing ID: SUCAI-14 2024-4-3 12:09
0Contribution points
Update time 2024-4-3 12:09
