Laser Creation into Class Course | Case 1: Postcard Philately design project
Postcard stamp collecting refers to stamping a postal or tourist attraction exclusive stamp on a postcard to commemorate the experience of traveling or sending postcards. Stamp collecting is the process of collecting multiple different stamps to stamp on the same postcard.
This is a traditional way of cultural experience, and during the stamping process, local residents and tourists can learn more about the cultural background and historical stories. At the same time, postcard stamp collecting is also a way of collecting. This collection method not only has ornamental value, but also allows people to feel the charm and emotional connection of time and space crossing.
Base design
Drawing Cover - Base design
0:1:13
Handle Design
Drawing Cover - Handle Design
0:3:55
Rubber seal
Drawing Cover - Rubber seal
0:8:20
Rubber seal production
(1)Enter the keyword "City Illustration" in Baidu Images Dongguan ", choose your favorite pictures to save; Click on 'Text' in the 'Function Area' above
[Item], then click [Open], double-click to open the saved Dongguan illustration image, as shown in the following figure:
(2) Click on the image with the left mouse button and select "Outline Tracing",Obtain the line diagram of Dongguan city illustration, as shown in the following figure:
(3) Left click on the left toolbar of the mouse and use the 'eraser' function to divide the connected Dongguan city illustrations into different buildings
Multiple individual buildings, as shown in the following figure:
Base production
(1) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'180, high130”, rectangle2For 'wide'150, high100”; Combine two
Copy the rectangle twice to obtain a rectangle3、4、5、6Among them, the rectangle4Adjust to 'wide'107, high87”Rectangle6Adjust to 'high'165, wide102”; In a rectangle3Compared to rectangles4Chinese
Insert rectangle between spaces7The width is36.5, Gao Wei70”As shown in the following figure:
Tips:Among them, rectangle1As the bottom layer of the base, rectangular3For the middle layer of the base, rectangular5For the top layer of the base.
(2) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw a gap1The width is2.6, Gao Wei10”Copy and paste it3Next, this is the gap group1Put it in
rectangle1Suitable location in the middle; Divide the gap group1copy and paste2Next, gap group2Place it in a rectangle3Gap group3Place it in a rectangle5As shown in the following figure:
(3) Left click on the 'Origin' button in the top toolbar, select 'Upper Middle' as the origin, and group the notches3The two gaps above are modified to 'Height is'3”; Select 'middle bottom'
As the origin, group the gaps together3The two gaps below are modified to 'Height is'3”As shown in the following figure:
(4) Click the left mouse button on the rectangle in the left toolbar to draw the slot1The width is9, Gao Wei10”; Draw card slot2The width is2.6, Gao Wei7”; Use the alignment tool
Align the "horizontal alignment" and "bottom alignment" in the tool, align the two card slots, and copy and paste the two card slots3Next, as shown in the following figure:
Handle production
(1) Select "trapezoid" from the "basic shapes" in the upper right corner, click on the shape, and select the "fillet" tool from the left toolbar to round the four corners of the trapezoid; adjust
The size of the trapezoid is up to 'width'95, Gao Wei60”As shown in the following figure:
(2) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'60, high36”, rectangle2For 'wide'5.1, high36”, then transform the rectangle2copy and paste1Secondly;
Transform the rectangle1Align the trapezoid with the center first, then align it downwards, and place the other two rectangles separately into the rectangles1Left and right sides;
Click the left mouse button on the "Origin" in the top toolbar and select "Take the upper middle point as the origin" to move the rectangle1Change to 'High'84”;
draw a rectangle3The width16, high84”, associate it with a rectangle1Center alignment; draw a rectangle4The width2.6, high42”Copy and paste it once, then place the two rectangles in the position shown in the figure below:
(3) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'35, high3”, transform the rectangle1[Array] Once, set the number of vertical arrays to2The array distance is4.35Obtain a rectangle2;
Left click to select trapezoids and rectangles1、2Copy and paste once to obtain a trapezoid shape1Compared to rectangles1.1、2.2;
draw a rectangle3The width71, high36”Compare it with a trapezoid1Center alignment and bottom alignment;
We will obtain a trapezoid shape1Compared to rectangles1.1、2.2, rectangle3Copy and paste once to obtain two identical patterns;
draw a rectangle4The width10, high3”The number of horizontal arrays is2The horizontal spacing is10Group two rectangles and combine them with rectangles2.2Align horizontally in the center and then align the rectangle2.2Delete, as shown in the following figure:
(4) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'22, high84”, rectangle2For 'wide'2.6, high42”Align the two rectangles' center 'and' top ';
draw a rectangle3Wide6, high3”Copy and paste to obtain a rectangle4Place the two rectangles separately into the rectangles1The bottom left and bottom right corners;
Transform the rectangle3、4Move upward 3mmAt the same time, transform the rectangle3、4Vertical array2The vertical array distance is-30.2mmAs shown in the following figure:
(5) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'40, high20”, rectangle2For 'wide'6, high69”, transform the rectangle2Horizontal array once, array distance is10Obtain a rectangle3;
Transform the rectangle2、3Group, get group1, group1Compared to rectangles1Center alignment;
draw a rectangle4The width2.6, high9”, compared to rectangles1Horizontal alignment and upward alignment, as shown in the following figure:
(6) Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw two rectangles1For 'wide'36, high10”, rectangle2For 'wide'3, high35”Align the two rectangles horizontally, rectangles1Right side and rectangle2Connected on the left side ";
Transform the rectangle1copy and paste2Next, obtain a rectangle3、4, rectangle3Move to rectangle1Connected at the top, rectangular4Move to rectangle1Connect the lower end and then connect the rectangle1Delete, as shown in the following figure:
(7)Set the "Right Angle Box" in the "Create" section of the toolbar at the top of the left mouse button to "Long"100, wide80, high40Waiting for parameters "," without top cover ", as shown in the following figure:
(8)Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw three rectangles1For 'wide'69.8, high39.6”, transform the rectangle1Align horizontally and vertically with the lower cover of the right angled box;
rectangle2For 'wide'14.9, Gao Wei9”, rectangle3For 'wide'4, high24”, transform the rectangle3Copy and paste once to obtain a rectangle4, transform the rectangle4Choose“90° "and place the rectangle3、4Horizontal centering "and" vertical centering ", then group them to obtain a group1;
Transform the rectangle2Compared to rectangles1Align, group1Place it in a rectangle2On the left side, along with the rectangle2to be connected;
Group the group1Copy and paste once to get the group2, group2Place it in a rectangle2On the right side, along with the rectangle2to be connected;
Transform the rectangle2Delete, as shown in the following figure:
(9)Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw three rectangles1For 'wide'2.6, high10”, rectangle2For 'wide'13, high3”, rectangle3For 'wide'10, high2.6”Place it in the following position in the picture;
Transform the rectangle1、2、3Group, get group1, group1Copy and paste once to get the group2And join the group2Horizontal mirroring, group2Place it in the following position in the picture;
Group the group1With groups2Copy and paste together once to get the group3, group3[Vertical Mirror], place it in the following position in the image;
Keep rectangles in each group1、3Delete the other rectangles in the picture along with the two crosses, as shown in the following figure:
(10)Left click on the left toolbar of the mouse and use the 'Rectangle Tool' to draw three rectangles1For 'wide'25, high37”, rectangle2For“68, high25”;
In a rectangle1Draw a rectangle up and down3、4All are 'wide'10, high3”, in a rectangle2Draw a rectangle up and down5、6;
Select the local area shown in step three, move it outside the lower cover, and modify the rectangle1The width of the two rectangles on the left is3, modify rectangle2The height of the two rectangles above is3;
Merge rectangles1、3、4Compared to rectangles1Two rectangles on the left to obtain the pattern1Merge rectangles2、5、6Compared to rectangles2Two rectangles above, obtain the pattern2;
Separate the patterns 1With patterns2Copy and paste once, as shown in the following figure:
(11)Left click on the 'Rectangle Tool' in the left toolbar of the mouse, draw a rectangle, 'Width'36.4, high35.4”,Select 'Font Tool' from the left toolbar and enter 'Lei Yu'
Laser ", set the font size to" one size larger ", as shown in the following figure:
(12)Copy and paste the two rectangles in the red area of the pattern on the right, move them to the second rectangle in the red area on the left, and delete the second rectangle;
Select the outer contour of the pattern on the right, copy and paste it once, as shown in the following figure:
(13)Copy and paste the two rectangles in the red area of the pattern on the right, move them to the second rectangle in the red area on the left, and delete the second rectangle;
(14)Transform the pattern1Obtained through the array11One, put the pattern on2Obtained through the array2As shown in the following figure:
Through the above steps, obtain the design drawing of the handle:
Laser processing
1、 Process parameter settings for rubber seals:
(1)Double click the blue layer on the processing panel in the bottom right corner with the mouse,Add custom material "rubber", double-click "custom" with the mouse, and separate English, Simplified Chinese, and Traditional Chinese
Don't set it asrubberRubber, rubber2mmDouble click the blank icon and select the rubber material image; Set the material, thickness, and process to rubber2mmShallow
Carving, as shown in the following picture:
2、 Base process parameter settings:
(1)Select 'Rectangle'1 ”Left click on the layer panel in the lower left corner of the mouse to change the layer to red;
Double click the red layer with the left mouse button to set the material, thickness, and process to acrylic3mmDraw lines; Double click the black layer with the left mouse button to set the material, thickness, and process separately
Set as acrylic3mmCutting, as shown in the following figure
3、 Process parameter settings for the handle:
(1)Select 'Leiyu Laser' ”Left click on the layer panel in the lower left corner of the mouse to change the layer to yellow;
Double click the yellow layer with the left mouse button to set the material, thickness, and process to acrylic3mmShallow carving; Double click the black layer with the left mouse button to select the material, thickness, and process
Set as acrylic3mmCut, as shown in the following figure:
Works Display:
Summary:
This course is the first introductory course brought by Laser Master to everyone. Compared with previous entry-level cases, this course is more complex and requires more thinking.
Firstly, we need to consider the structure of the work, decompose it, understand its structural composition, and complete the design drawings. Note that during this process, we need to perform laser compensation design on the drawings and increase or decrease the hole positions1-2mmModifying the size can make it easier to assemble the artwork.
This case has a certain level of difficulty, young designers need to have enough patience to complete it!
drawing ID: SUCAI-22 2024-4-8 09:15
0Contribution points
Update time 2024-4-8 09:15
